I agree with AP72 that you probably haven't helped or hurt anything. Current thinking has the intake ports left rough and the exhaust ports polished, but unless I had a Doctorate in Fluid Dynamics or many years experience grinding on heads, I'd either leave 'em alone or take 'em to someone who knows what to do to them and how to do it. Also, think about what it takes to port match. You end up with a runner that looks like an Anaconda that swallowed a pig (the passage runs standard volume, then enters your increased volume section, then necks down again). Where the passage gets larger in volume, the air/fuel mixture slows down and can drop fuel out of suspension, particularly if the surface of the port is polished, resulting in puddling and a rich/lean/rich/lean condition. There is a boundary layer in any port where the surface can be as rough as a fingernail file and not hurt flow.
I generally refer to a river in order to explain this. If you stand at the bank of a river, you'll see that the major volume of flow and speed is right down the middle and that the flow is very much stalled at either bank of the river. Same way in a port, fast down the middle and slow at the surface of the port. |
Bogie |
Porting vortec heads will only gain you a couple more HP. They were made to flow as much as possible from the factory already. They did a good job making them you're not gonna improve much on what they've already done.
In the future what you can look to remove is any "overhang" into the port that is seen as viewed from the intake into the head's intake port. You don't want any of the head's intake flange obstructing the flow from the intake manifold's port into the head. If there's a mismatch as seen looking from the head back into the intake, this can be ignored. Actually, some say this mismatch can reduce reversion in some cases. It takes careful measurements to get this precise- to the point of mocking up the heads on the block then mounting the intake using templates (or intake gaskets) as references. What can happen when doing a simple gasket matching of the ports, is a bulge is created where the head and intake meet. Someone here referred to it as looking like a snake that ate a rabbit, or something like that. This is to be avoided! What will happen is the flow slows as the cross section enlarges and this can cause turbulence and reduced flow. You can do a search for port matching as opposed to gasket matching for more details. |
| port matching vs gasket matching? | steveyb4342 | Engine | 2 | 04-07-2007 06:41 AM |
| Port matching intake | 57NAPCO | Engine | 5 | 03-04-2005 10:10 AM |
| Intake port matching. Help please | 67 Deuce 4 Me | Engine | 7 | 12-12-2004 04:40 PM |
| Intake port matching AFR heads | 406chevelle | Engine | 2 | 01-16-2004 05:26 PM |
| port matching heads and intake | nosliw721 | Engine | 1 | 12-23-2002 04:47 PM |
