Intake port matching AFR heads
I am about to purchase an Edelbrock RPM Performer (maybe the Air Gap) intake manifold and intake gaskets, it looks like my AFR 195 heads need a little intake porting, so I am going to port match the intake manifold and head intakes.
From reading the board all the time it appears that several people have experience with AFR heads, so I hoping someone has the answer to the following question
Can anybody tell me the correct Fel-Pro (or other brand) 400sbc gasket that matches the AFR 195 heads????
The intake port size on the heads is 1.280” X 2.090” with a 3/8” radius, Fel-Pro has a gasket that matches the dimensions but AFR says it does not line up correctly to the intake ports.
Any help is greatly appreciated.
406chevelle
