intake question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2009, 08:01 AM
intake question
Hopefully an easy intake question. 350 chevy good size cam, 4.060 bore, 180cc heads. Was recommended that I use 6500rpm intake (i.e. Edelbrock Peformer RPM) BUT, have a buddy with a 5500rpm intake (Edelbrock EPS) that I can get dirt cheap brand new. Will the 1000 rpm make any difference on a truck that is mostly driven around town.
Old 03-20-2009, 08:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IMO, I'd get it and use it as a trade or sell, if the deal is real sweet.
Then I'd go w/the RPM.
But this depends on the cam and engine combo and what you're using it for, etc.
Got any details?
Old 03-20-2009, 08:16 AM
For starters I have a 71 Chevy C10 350ci 350 turbo tranny 2wd.
350ci
Bored .060
Lunati bracket master cam #00017 w/ hydraulic lifters
.460 intake lift
.460 exhaust lift
1.5 rocker ratio
290 duration
edlebrock 650 carb
180cc RHS heads 2.020 intake 1.600 exhaust
Old 03-21-2009, 03:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That EPS should be fine w/that combo. I'd go for it.
Old 03-21-2009, 04:43 AM
Thanks I assumed it wouldn't make much difference with what I am using it for, just needed the added assurance. Just wondering, where would the RPM range make a difference? Is it just more air flow, more horsepower?
Old 03-21-2009, 06:46 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Well. the RPM intake has a larger port volume and shape (compared to yours), to supply an engine to about 6500 rpm.
The Performer or your intake is sized smaller in that regard, so works better at less rpm, but would create a restriction above about 5500 rpm.
Old Holley Intake Question.... HawkZ28 Engine 10 02-28-2011 11:19 PM
intake gasket question thefloyd1973 Engine 3 05-25-2008 08:26 PM
porting a intake question Jamie Thomas Engine 7 04-11-2008 08:04 AM
carb and intake question hddave1 Engine 12 03-30-2008 10:33 PM
Vortec intake question? crseth Engine 11 12-19-2005 07:25 PM
