Intake Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2012, 09:48 PM
Intake Question
I've got a slightly warmed over Sbc 350. It has an Edelbrock intake on it. The only numbers i can get off of it is C3BX. It appears to be a high rise dualplane. Engine runs strong, I was just wondering if anyone knows if this intake is any good or should I be looking for something else.
Old 11-10-2012, 10:41 PM
Intake Question
According to some other folks on another forum it is an older intake for a 327. They say it has large intake runners. Does it have a tube in front for the oil fill? Also those intakes with the Holleys and Qjets would fit under the hood on Vetts unlike the Performer RPM intake.
The Following User Says Thank You to cdminter59 For This Useful Post:
greenmachine72 (11-11-2012)
Old 11-11-2012, 12:00 AM
327NUT's Avatar
Yes it's an older intake but it will work just fine for a mild build. No reason to spend the money or change it for a newer Performer just to cruise around on the street.
The Following User Says Thank You to 327NUT For This Useful Post:
Old 11-11-2012, 12:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The C3BX and it's sister, the C3B (a photo of the one I own is below) were originally made to use the Holley 3-barrel carb. The 3-barrel carb ended up not being the world beater Holley had hoped for. That's the reason for the small notch in the plenum divider- to clear the wide secondary throttle blade of the 3-barrel carb. The Holley Dominator carb replaced the 3-barrel and the rest is history.
The C3B/C3BX intakes aren't bad pieces, but through the years the changes in how we build engines up have brought changes to the shape and volume of the manifold ports and plenums that improved on the older designs.
Today, for a mild build a Performer p/n 2101 is a good choice. Or if you're using a squarebore carb and want a little extra bottom end, the Performer EPS p/n 2701 is a good choice. These p/n's are both for the 1986-back heads. Check the Edelbrock site for other applications.
Good luck.
The Following 2 Users Say Thank You to cobalt327 For This Useful Post:
greenmachine72 (11-11-2012), techinspector1 (11-11-2012)
Old 11-11-2012, 08:26 AM
Thanks for the info. I will be using a Edelbrock 1406 carb. do you think its worth filling in that notch to make it a true 180 degree manifold?
Old 11-11-2012, 09:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I doubt it. The primary side of the carb is sealed off from the notch. Having it open only to the secondaries won't hurt anything.
Old 11-11-2012, 01:20 PM
JeffB's Avatar
Only thing is you will need to run a small base distributor,an HEI will not clear the back runners.Actually the C3B will out perform the Performer 2101.
Old 11-11-2012, 06:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you don't mind a little grinding, the HEI will fit. Won't fit as-is, though.
question about an intake durand322 Engine 2 02-22-2010 03:54 PM
intake question neverfastenuff Engine 3 07-07-2009 07:36 PM
Intake Question stoney 81ta Engine 6 05-11-2006 10:43 PM
Intake question almega Engine 2 06-12-2005 02:28 PM
Intake question? lucas_04 Engine 1 12-14-2003 11:07 PM
