Intake recommendation for BBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 10:13 PM
truckboy61's Avatar
Carb - Holley #9188 cfm 780 type (4150) , 454 BBC , closed chamber 206 heads. I don't understand the flange questions nor intake terminology please explain , want to purchase correct intake first time buying a after market intake.
Old 06-13-2010, 10:35 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Not sure what you're talking about here, but if you want to make the most power from 1500 to 6500 with a BBC, then use either of these intake manifolds....
http://www.summitracing.com/parts/EDL-7161/
http://www.summitracing.com/parts/WND-8019/
If it is unacceptable that neither of these manifolds make power from idle to 1500 (no matter what the blurb says concerning the Stealth), then use a looser torque converter to get the motor up to 1500+ before it begins to pull hard.
If you need to make power above 6500, for instance with a circle track motor, then you should consider a single plane manifold such as the Edelbrock Victor series.
Old 06-14-2010, 08:16 AM
truckboy61's Avatar
Thank you for the recommendations
I lose compression w/ valve adjust drivehard Engine 6 11-23-2009 09:29 AM
Removing intake on SBC... help! v8hed Engine 14 06-06-2008 04:35 PM
Need Hood Clearance - Intake ? 68chevelle_ss Engine 6 06-30-2005 08:10 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
