I have a 1968 chevy 302 in my 1969 camaro. It has all of the origional parts except for roller tip rockers. Double hump heads, 2.02/1.60 valves, the offroad special Mechanical - 257/269 intake - .493/.512 exhaust camshaft, 11:1 compression, hooker headers, 750 speed demon carb, msd billet distributer with 6AL box. I am running it with a saginaw 4-speed for now. I currently have a dual plane performer on it and I know that it is not anywhere near its full potential with this intake. I am fine with a single plane intake, I have been looking at the Victor Jr.s and Torker IIs. Do you guys have any suggestions. Remeber the major horsepower range is between 3500-7800.
Thanks, ELi |
Street only. I have been known to go to the strip once a year. Will the Victor Jr. be hard to street?
Eli |
If you are running in that rpm range,a single plane would probably be your best bet,that puppy must wind up pretty good.I built one for a 83 Z-28 with a 5 speed and had nothing but a good time with it.
intake
i have had really good luck out of a holley strip dominator . it flows good rom 3500 to when i shift at 7000 on my 468
I agree with Vince...
Dual plane factory style intake and drop to no more than a 650 DP, that 750 flows more like an 800-850 anyhow and kills that small cube engine on the low rpms...
intake recommedations for 302 chevy
i would us a rpm or a air gap rpm i had a new zz4 i took the factory intake off and installed a 1969 302 intake i have in stock the hot cam kit and a 750 speed demon carb in a 55 chevy it ran great befor i sold the car i took my 302 intake off an install the factory intake it KILLED IT 5500 or a little better an it was done
302 intake
Dear Sir I Would Go With A Victor Jr. Intake.I Have A 302 In My 67 Nova With a SupperVictor On It And It Is Very Streetable. Only Because Of The Short Stroke. It Revs Faster And Gets You To Your Power Band Faster My Car Works Well From 1500 To 8500. And Is Very Steetable No Problems
I would stick with the performer r.p.m. or performer air gap. You would'nt probably be disapointed with the torkerII, another alternative is the g.m. performance parts highrise cast iron dual plane intake. it's a drop dead copy of the z-28 intake with a 1/4in. taller deck,and dual flange carb pattern. Just paint or powdercoat it grey, and you have a stock-looking z-28 intake! I HATE the zz4 stock intake with it's e.g.r. boss, and impossible to tighten center bolts around the e.g.r. flange!!
