Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intake runners and superchargers?
Old 01-13-2012, 07:43 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Chet's right on, there's nothing wrong with that manifold, it's typical. Keep in mind you're force feeding a blower motor, port velocity as it relates to a NA motor doesn't come into play under boost. Other than that intake bolting to the heads from the inside, it works. Take a look as some top fuel setups, you'll see the blowers and injector hats appear offset by a bunch.
Semper Fi
