Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intake swap: dual plane airgap to single plane ?
Old 09-18-2009, 05:31 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
This particular intake is not that bad for an old single plane, but make sure you use it with the divider as it will help low end a lot. This intake(Wieand Accelerator #7546 w/divider) has been out of production for close to 10 years, so it may not have enough material to cover some of the newer +.100" raised intake ports. Check before you just bolt it on. If it will work, I would use it as a test to rule out head problems and then replace it with a new piece geared toward your build if the problem is solved.
The PP Crosswind, and the Typhoon(dual planes), come up in a lot of problem threads around the web, strangely the PP Hurricane(big single plane) hardly ever. Have used the Hurricane without problems, but know a friend that had driveabilty issues on his street rod using a PP Typhoon dual plane(non air gap like an Performer) and took the polished PP intake off and put the Performer back on and the hot start and sputtering problems went away.
