Intake technical info
I hate to ask a stupid question, but feel it is moronic not to ask if you don't know.
What do the rpm ratings on intake manifolds mean? I.e., Weiand Stealth High Rise is rated for 1500-6700 rpm. Thanks, Scott |
there are no stupid questions, just stupid people
![]() Intake port size and flow is set up to provide a range in which it will make its best power. Small runners will mean that the flow will reach high velocities earlier in the engine's RPM range. Basically an engine operates based around several compromises. Peak velocity is associated with maximum cylinder filling and turbulence which means it helps torque. Peak flow is associated with how much air it can move and therefore HP. Selecting an intake for your engine is as simple as selecting a runner flow that won't choke it on the top end, but isn't so big that it kills velocity. Its always a trade off. The published RPM ranges are very general (sometimes exaggerated) numbers that help you pick which one you need, but its important to note that those numbers are usually based on a common engine. An RPM range for an Edelbrock Performer for a small block chevy might say 1500-5500, but that is usually a guideline based on a 350. That optimal RPM range on a 305 might be 2000-6000, and on a 383 it might be 1000-4700. |
Thanks for the info. It makes sense unpon explanation.
A lack of knowledge does not translate into stupidity.
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| DeSoto Intake Interchange | 345 desoto | Engine | 3 | 01-07-2009 10:05 AM |
| Holley intake info???? | shotton | Engine | 3 | 08-22-2006 07:54 AM |
| Eldebrock C33B intake info | Alvin Tench | Engine | 3 | 07-02-2004 12:26 AM |
| Madd Syntst. U get the intake info I gave you? | HemmiGremmie | Hotrodders' Lounge | 1 | 08-01-2002 08:47 AM |
