intake vac leak
howdy. i have had no luck with this engine. the problem NOW i am having is i have put two intake gaskets on the intake and still have a big leak coming from the side of intake. first set of gaskets i used Mr. Gasket on it and it leaked. i sprayed carb cleaner on the intake and rpms went up. next set of gaskets i used fel pro, hi tack gasket and silcone plus washers on intake and still leaked.
is there any solutions with out taking off the intake i want to find the solution my truck has been down two months and it is my dailey driver. it is a 350 bore 40 over 882 heads and edlebrock intake. i am tried of geting rides from people. one dude said i need to take off 60 thousands or somethin from the intake thanks.
Is the intake warped? Are the heads machined down for high compression? If yes, then the intake probably should be machined down a little... I feel bad that your DD is out of service, I know how that feels.
At least with me it was only 2 days... edit: wow jmark must've been making his post at the same time I was, lol... |
the intake was on my 305 before i did motor swap and i had no problems. so i don't think the intake is warp. the heads where milled i little to clean them up a little.
Someone else wrote the first part of this article. I wrote the last part beginning with the word "occasionally". Maybe it will help you sort it out, although the manifold will have to come off.
http://crankshaftcoalition.com/wiki/...d_Vacuum_Leaks |
| Building A 302 Chevy | Scorpio Shaping Flow | Hotrodding Basics | 6 | 01-16-2007 05:55 AM |
| vacuum leak? | airman_turtle | Engine | 3 | 02-20-2005 10:01 AM |
| Dart intake? Brodix or Dart Heads? | Slowass72 | Engine | 3 | 01-20-2004 04:52 PM |
| Intake port matching AFR heads | 406chevelle | Engine | 2 | 01-16-2004 05:26 PM |
| Intake | Chevy Guy | Engine | 2 | 04-27-2003 08:06 PM |
