Which intake for Vortec Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2006, 07:38 PM
Old 09-14-2006, 08:02 PM
327NUT's Avatar
I looked in Summit catalog, looks like the Edelbrock #2116 will work, better yet you go to Edelbrock.com and look under performer intake manifolds.
Old 09-14-2006, 08:11 PM
CNC Blocks Northeast
Originally Posted by BC 73Vette
Hey all
I am seriously thinking about a GM 350/330 HP Crate engine to drop into my 1973 Corvette
The new engine has Vortec heads and I will need a new intake to mount my Quadrajet on
Any suggestions as to which Intake I can use?
The Edlebrock Performer 2101 with the QJ fits under my hood with about 2" to spare
I need to know what intake I can use with the Vortec heads
Thanks
We have used both Elderbrock on street and strip engines we build, 7116 which is the Peformer RPM and I like the 7516 which is the RPM Air Gap intake which we use if the customer wants spend a little extra money.
Old 09-14-2006, 08:12 PM
Old 09-14-2006, 08:15 PM
Originally Posted by CNC BLOCKS N/E
the Peformer RPM
The RPM Manifold wont fit with the stock Cold ait induction air cleaner setup
Thanks though
Old 09-14-2006, 08:18 PM
bigblock454camaro's Avatar
No substitute for cubic inches
Last journal entry: 1946 Chevy Fleetline
I built a 350 with vortec heads for a guy with a 80 vette last year. We used a Cyclone intake. It is basically an Edelbrock intake, you can't tell any difference in the two except for the price. We got the Cyclone for around 130 whereas the Edelbrock was around 200, I think. But anyway it fits under the stock hood with no problem. Also if you want to use the stock Vette valve covers with the centerbolt adapters, throw the gaskets that come with the adapters away and get thick Felpro cork gaskets. The steel reinforced gaskets that come with the adapters leak no matter what you do. Good luck with it.
Old 09-14-2006, 08:28 PM
Old 09-14-2006, 08:38 PM
One other thing to remember is you have vacuum operated headlights. Too much cam, no lights I have the cam specs here that we used it is a comp XE256H-10 212/218@ .050 447 int 454 ex. That's what my machinist came up with on our combo. If you have any questions on the build pm me cause we have already done the vortec vette.
Old 09-18-2006, 08:51 AM
Ozz1967's Avatar
Air Force Guy
GM Performance Parts makes a vortec intake that will fit a Q- jet. I don't recall the part number off the top of my head, but it looks good.
Anyone build 351C 2V heads w/460 intake valve? Aussie XAXB Engine 2 11-20-2005 07:56 PM
NEW GMPP VORTEC heads !! terror385 Engine 1 07-11-2004 09:48 AM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
1997 5.7 Vortec Conversion 71ChevySWB Engine 2 01-14-2003 07:42 PM
port matching heads and intake nosliw721 Engine 1 12-23-2002 04:47 PM
