Intake water outlet fitting removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2010, 02:35 PM
daveh's Avatar
Hey guys,
I have two water outlet fittings rusted in my aluminum intake. I've been soaking them for a week with PB Blaster but they won't budge. Can I heat them up without hurting the intake integrity? If yes do I heat the fittings themselves or where they enter the intake? Any suggestions would be great. Thanks
Dave
Old 04-09-2010, 03:21 PM
Heat and cool...repeat
I have had the same problem and I heated both, the aluminum has a high expansion coefficient so it will expand more. Anyway heat is up let it cool 2-3 times and it should release some of its grip on the steel fitting.
The only caution is that unlike steel which changes colour when heated the aluminum will liquefy all of a sudden if heated too hot and then your manifold is ruined.
Gunked up 454 Intake Water Port 31fordcoupe Engine 8 01-18-2010 04:08 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
water neck outlet on 350sbc question 73chevyhelp Engine 8 10-15-2004 10:47 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
water pump fitting leaking brian400ex Engine 4 03-22-2003 06:06 AM
