Intakes sucking oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 01:13 PM
Last journal entry: Photos
Intakes sucking oil
I 'm having a problem with heads sucking in oil at intake gaskets. I replace gaskets and it improves a lot but still leaks a little. So I retighten(30 ft/lb) and then it gets real bad immediately. I'm stumped. RPM air-gap, FelPro 1205s, rebuilt Gen 1 GM heads(Aerohead). Is this a sign that the the heads were shaved more than I thought. I figured a few thousanths but maybe much more?
Old 03-18-2012, 02:01 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Check the manifold with a straight edge, it may be warped. Or temporarily use two gaskets on each side & see if that cures the problem.
Rich
Old 03-18-2012, 02:59 PM
My new engine sucked oil like crazy and I went through three rounds of gaskets before I got the advice here to see if the valve seals were teflon. I replaced them with viton and have been oil free since. just my 2 cents.
Old 03-18-2012, 03:32 PM
I installed vitons "and" umbrellas on the intakes. Just vitons on the exhaust. I've always had intakes suck oil down. I'm sure its the runners. I forgot to mention its only doing it on one head now. I'll check the intake flange with a straight-edge next time its off. Gotta get more gaskets. Maybe its a gasket /port match?
Old 03-19-2012, 07:41 AM
RWENUTS's Avatar
What bolt tightening pattern do you use when you install the intake?
Old 03-19-2012, 08:02 AM
Edelbrock site, pre-1995 sbc sequence. I'm going to use feeler gauge with no gaskets to see if theres an angle.
Old 03-19-2012, 08:06 AM
RWENUTS's Avatar
A trick for you. When you put the intake on dry with no gaskets put a flash light inside on the lifters. You'll be able to see the gaps or imperfections way easier.
Old 03-19-2012, 08:10 AM
Good idea!
proformance products intakes = edelbrock intakes? stewartcannon Engine 17 05-31-2011 12:53 PM
Heater - sucking air from outside? staleg Hotrodding Basics 9 02-08-2011 09:58 AM
Sucking My Oil Pan Dry goingonmotor4 Engine 11 08-23-2009 11:23 AM
GMPP 454 sucking oil Bryan59EC Engine 14 08-31-2007 04:02 PM
sucking noise Super Chevy Engine 6 11-29-2004 10:01 PM
