Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intank or Inline FP?
  #18 (permalink)
Old 10-24-2012, 10:21 AM
ap72 ap72 is offline
Banned
Originally Posted by zildjian4life218 View Post
Also right now I have one of those $20 holley regulators. Should I step up to something like this. Then I could run 3/8" feed and return and also have the possibility of swapping to efi down the road which is in the predreaming/planning stages.
If you're going to swap to EFI now is the time to do it- it'll never be cheaper or easier. Even if you can't afford a good multipoint system a junkyard TBI unit on top of your carb manifold is a great way to get started. That way you'll have your EFI fuel system already in place should you decide to upgrade to multipoint down the road.
FWIW you can convert to TBI for less than the cost of a new carb. You can also swap in a JY distributor allowing computer controlled timing advance. 400hp will be maxxing out stock BBC TBI injectors though, the BBC throttle body itself will flow more than enough air with a little finessing.
