Originally Posted by E.Furgal
the 454tbi is 2" throttle blades and 550 cfm
the small block is 1 11/16th and 500 cfm
the big block injectors flow 70 x2 is 140
8x24 is 192
one bottle neck coming right up. one must remember these tbi454 where peanut port headed engies with intake ports smaller than some small blocks..
good luck with your goal of 400hp.. hope you get there..
the data of parts being planned on being used , it don't look good..
your an fyi.. mr 72 in a thread on here "carb confused"
Im terribly conflicted... Carbs
post a 350 will need 750cfm..
now no matter what I think(650cfm) his post on that thread and him telling you you'll get to your goals with a 550cfm tbi.. well.
now if it was a 550 throttle body dry.. no fuel then maybe.. squeak by.. and thats a big if..
carry on..
The TBI injectors were rated at 80 or 85 and I can triple the fuel pressure going to them (Which equals more flow)..... I would think with your vast knowledge you would have understood that. As stated already by AP and myself by cranking up the fuel pressure on the LT1 injectors I can probably get by.... which Would only leave me with needing to buy an Aftermarket intake and doing all the extra wiring for the MFPI vs the TBI setup.
Try This Out Click the witchhunter link.
