Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intank or Inline FP?
  #50 (permalink)
Old 10-25-2012, 02:35 PM
E.Furgal E.Furgal is offline
Last journal entry: was hoping for better than this
Originally Posted by zildjian4life218 View Post
The TBI injectors were rated at 80 or 85 and I can triple the fuel pressure going to them (Which equals more flow)..... .
you can't up the fuel pressure that high.. the tbi regulator won't take it.. for one.
like a carb cfm there is a point that no matter how much psi you hit it with it doesn't flow more fuel through the injector ..
remember you have 2 injectors not 8.. getting 3% more flow out of an injector then times 8 makes a little differance... 3% more flow out of 2.. isn't gonna cut it..
buy the way the bbc injector rating of 80-85 is to high of a duty cycle.. for any long term use... drag car.. fine.. long hyway run.. you'ls let the smoke out of the injector drivers
