Interchangabilty of front fender wells between 72 2dr Chevelle and other A body's - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2011, 07:55 AM
My recently acquired 2dr 72 Chevelle has some mangled up plastic front inner fender wells which needs replacing. I know new ones are readily available but am looking first for some 'steel' ones in salvage yards. Does anyone know if other 68-72 'A' body car fender wells are innerchangable. Only thing I have located in local salvage is a 72 Ponti Lemans..don't know if they'll fit.
Old 05-10-2011, 06:11 AM
jalopy45's Avatar
Find a friendly wrecking yard that has a Hollanders interchange Manual and it will tell you the specific cars or trucks that use the same fender wells. I have then up to 65 and they list body and mechanical parts interchanges.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 05-10-2011, 09:34 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I don't think any inner other than a Chevelle will work.
Buick, Olds & Pontiac all have way different inners and core supports.
I also think you may be limited to 71-72 Chevelle---and maybe just
the 2dr 72.
72 2dr front ends are different than the wagon/elky, but may interchange with the 4 dr sedan.
As similar as the 66 and 67 cars are --the inners are way different and will not interchange unless the whole front clip is changed.
You may have the same issue with the 72
Old 05-10-2011, 11:29 AM
dinger's Avatar
68-72 Chevelle and Malibu. Wagons and El Caminos are the same but different than the 2 and 4 doors. They can be used if you want to drill some holes for the bolt into the cowl.
This place has metal ones at a decent price, I don't know if you will find them cheaper in a wrecking yard or if they will separate them from a decent fender.
http://www.chevelle.com/Inner-Fender-Kits-C744.aspx
This store is in N.C. Shop around on the net for a place close by, the partsare often metal and are popular to a guy building a Chevelle.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
72 chevelle front inner fender wells spartan74 Body - Exterior 2 05-02-2011 03:10 PM
33 fender wells jerrys1933 Body - Exterior 1 02-14-2011 01:07 PM
No front fender wells 454headache Hotrodding Basics 4 10-31-2009 01:54 AM
67 ss chevelle front fender flag placement gun70runner Body - Exterior 5 07-29-2008 07:18 PM
NEED INNER WELLS AND WILL CHEVELLE WELLS WORK INSTEAD OF PLASTIC? 72chevyelcamino Body - Exterior 1 10-21-2002 06:15 PM
