Interchangable Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2007, 09:23 PM
MrPhotographer06's Avatar
Krazy Kid
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
on a 63 C10.. without having to change axles or anything. what disc brakes would fit?so i wouldnt have to go WAY expensive and buy a new conversion kit all i had to do was transfer and hook up the lines.. at the least.. i'm expecting some work.. but with less then buyin a 300 dollar 2 wheel brake conversion kit
Old 06-16-2007, 10:17 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
The thing to remember here is that you will need to have something to mount the calipers to. As soon as you change the spindle knuckles, you have to also change the tie-rod ends and ball joints.
If I recall correctly, the 63 may have had torsion-bar front suspension instead of coil springs like my '66.
Have a look at my journal and see if your front cross-member bolts in the same way as mine. My frame also "kicks up" under the front suspension ... so be aware of that as well.
If everything appears the same as mine, then a trip to the wrecking yard for a front suspension clip for a 73-79/80 C10 would be in order. (80/81 to 87 will also fit, but they use a Metric power steering box.)
My thought was that if I change the whole suspension clip, then I don't have to try to remember what year each component fits ... all my steering and brake components are all "1976" (except for the 6-bolt rotors ... which are "special".)
Be sure to grab the idler arm as well, as they are different than yours, too. Mounting it is also very easy ... 2 holes to drill in frame.
Edit:
Oh Yeah ... get the front sway bar and mounting brackets while you're at it. They are riveted to the frame, so take a smoke wrench or grinder with you. You'll also want a BFH and a good punch to knock them out as well.
Old 06-17-2007, 06:36 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Edit:
On a 63 2wd they use the same suspension through 66, coil springs.
Old 06-17-2007, 06:40 AM
1ownerT's Avatar
Wiki Edits: 4
If going to front disk, you will need to change the master cylinder. Depending on what comes with the $300 kit, it may be well spent money.
Old 06-17-2007, 06:54 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I've read some of your threads. I see you are 14. You have jumped from bugs to mustangs, and now an old 63 pickup.
I just don't know why you would even think about buying a disc kit for a truck that you haven't even checked to see if it's all rotted underneath.
14 years old?, been there done that.
Pick a good SOLID builder & stick with the basics.....get it to run good and then go from there. Plus pick something you can afford to drive on teenager "part time job pay". I've got a couple of those trucks all done up with V8s,auto, ps, pb,etc, and it costs me 10 bucks in gas just to go visit a friend on the other side of town
That 63 does not need discs. If you run it with manual steering and non-power disc brakes and an old column mounted 3-speed, & 230 six, it will "feel" just like what it is supposed to....an old worn out farm truck....not a rod.
You need to stare at those 63 pics real good and start a price list of ALL the parts just to make it fit for the road. All new brake parts incl hoses, cylinders, lines. Exhaust, waterpump, hoses, belts,engine gaskets-seals, carb kit, air filter,gas filter, windshield & mounting seal, door seals, door window run channels & felts to make the windows work, door latches at $99 each! (they are always shot on 60-63s), steering & front end parts, shocks,better seat, sandpaper, grinding discs & flat black cheapy paint......etc, etc, etc......at least $1500-$2000 and then you still have a farm truck, not a rod. And then if you hate it, be prepared that if you try to sell it, it may bring only $500 because it's still got a worn out six & 3 speed, and rusted out underneath.
I hate to pick on you but I saw you get excited about the bug and after powerwashing it and pulling the body, you QUIT! That truck will end up the same way because you are not yet up to the task of restoring things. Old rusty cars & trucks are a money pit and a job that requires tons of equipment & experience. Save your $ and find something solid and one that has had a lot of money invested but not quite finished.
Old 06-17-2007, 10:33 AM
Krazy Kid
the brakes ..was just an idea
this truck runs.. it ran 2 years ago and we drove it around the yard.. it just needs a refreshing..
the bug.. needed a new everything..
rebuilt tranny ( that i dont even know works) engine (now has starter problems) and then about 3000 dollars worth of parts
the truck.... needs probally brake shoes and wouldnt hurt to go through the tranny
i dunno..
i like the truck more than the VW.. i'll just finish it when i get more experience
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes DoubleVision Suspension - Brakes - Steering 2 11-11-2005 01:51 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
