interchangeable power steering pump ? with what ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2010, 02:09 PM
previous owner attempted to put AC on this motor, added the power steering pump with the double pulley. I need to remove the double pulley, problem is, the double pulley pump has a longer shaft, I don't think I can put a single pullety on it. One junk yard said this pump was only a 68 to 71 and Cutlass only . Another yard said all GM's are the same .....question, what pump will fit on this "69 Cutlass, 350, with out AC ??????
Old 12-16-2010, 06:53 PM
SSedan64's Avatar
I'm with the other Yard, I think only the Pulley is different, not the Pump.
Look them up here>> http://www.rockauto.com/catalog/raframecatalog.php
Click on the "More Info" link for part Pics,
Click on Part# for vehicles & years they were used on.
Old 12-17-2010, 10:18 PM
a little more research on the interchangablity of the pumps.... seems as thou the cutlass pump is the same as a chevelle, but the reservors are differnt. Oldsmobile must have had differnt ideas.......also, I found out some of the wiring harnesses that do the same job, are differnt ! Back to the P S pump..... I think , in order to get rid of the double pulley, the pump also has a longer shaft because of the thicker pully, I have to buy the pump insides ( about $40 ) use the Olds reservor, and then all I need is a single groove pully..............or......... I could find a used GM pump assy, and just change the reservors
Power Steering Pump question for a 4.3 Liter knothead Engine 3 05-03-2010 08:24 PM
Power steering pump on blown motor Marcus Engine 14 05-16-2008 01:10 AM
power steering pump question 46 chevy pickup Suspension - Brakes - Steering 7 08-25-2006 07:05 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
