interchangeable transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 07:42 PM
I have a 1993 Ford Mustang with a 2.3 engine with automatic overdrive. I have a 1987 Ford Ranger with a 2.9 engine with automatic overdrive. Will the 1987 transmission fit the 1993 transmission?
Old 09-04-2006, 03:04 PM
the mustang has an A4ld trans and the explorer most likely has the same, but if the explorer is 4x4 it won't bolt up, take a peek under and see if the explorer(if 2x4) has the same trans as the mustang, the A4ld is different because the bellhousing unbolts, if it does then your in luck,
they are not electronic so yes the will bolt in then
Old 09-05-2006, 07:08 AM
tnsmith10's Avatar
when will it rain???
they have the same trans, but, the bellhousing and the outputshaft would have to be swapped out...
More transmission troubles chrisflock Transmission - Rearend 3 08-10-2007 11:07 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
