I don't know what sizes you're working with in the Vortec heads, any chance you could use 3/8" inserts? There's always 7/16".
I can't go the 7/16 route as I don't want to have to buy another set of rocker arms. I'm also not sure on the inserts for 3/8. It looks like I'll just have to take them to my machinist and see what he says. I think I see why they used inserts as the surrounding cast iron is rather thin.
Unless the head castings had holes originally made for pressed in studs and the insert was the only way to use the hole. I'm thinking if the heads were drilled for pressed in studs, the holes would be too big to thread them for what's in them now, so they'd have to h-coil them. |
somebody tell this guy that there is a cheaper way.
Almost anything that you want (short of the obvious parts, the rods and a couple other parts) for the Vortec 4.3 is interchangeable with sets from the sets from Vortec 350s. You wil just have couple extr parts in the sets. Check out the ARP rocker studs for the Vortec 350.
The threads in the 1997 V6 heads are M8-1.25 for stock M8 x M8-1.25 studs. If someone has installed inserts in those heads, they may have used M10-1.50 helicoils for ARP 100-7201, 3/8"-24 x M10- 1.50 adjustable conversion studs. A heli coil was unecessary because they could have used ARP 134-7201 3/8"-24 x M8-1.25 rocker studs. However, the ARP 100-7201 and 134-7201 conversion studs are too short for aluminum full roller rocker arms and 3/8"-24 poly-locks.
You can use ARP 134-7104, 3/8"-24 x 7/16"-14 rocker studs designed for a SBC V8. The effective length of those studs is .300" longer than the ARP 100-7201 and .155" longer than the ARP 134-7201 conversion studs. The ARP 134-7104 studs for a V8 are long enough to work with 3/8"-24 aluminum narrow body, full roller rocker arms on a V6. However, you must drill and tap the heads for 7/16-14 base threads and install #57615 Time Serts instead of helicoils. Those TimeSerts require a 37/64" counter bore. Use self aligning rocker arms on V6 heads because the guide plates designed for a V8 are made for different valve and push rod spacing. You will also have to use ARP 233-3701 (12 pt.) head bolts for clearance of your torque wrench socket. You may or may not have to correct your push rod length, depending on which camshaft and roller lifters you use. If the above solution is too costly, use stock or Comp Cams 1412 ball fulcrum, roller tip rocker arms with the ARP conversion studs that fit the helicoils already in the heads. Most people trying to solve the V6 rocker stud problem choose that option. |
| Interesting find in my parts car. | MARTINSR | Hotrodders' Lounge | 4 | 11-15-2010 02:23 PM |
| Some interesting sbc head data | turbolover | Engine | 0 | 11-03-2010 01:16 PM |
| interesting find with VW 1600 DP aircooled | matt167 | Engine | 1 | 09-13-2010 04:35 PM |
| Chevy head 482824?? I cant find ne listing on this head?? | 89SDime | Engine | 3 | 01-27-2006 08:51 PM |
| Interesting Find w/ Engine Calculator | strikingthematch | Hotrodders' Lounge | 5 | 01-25-2005 03:26 PM |
