Interesting heater problem with my Rambler, any ideas? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-16-2012, 12:42 PM
ogre's Avatar
the 'Duracell Project'
then you're screwed, so screwed
dang alien gremlins
  #17 (permalink)
Old 02-18-2012, 09:40 PM
I had to post a few photos of that fan, just so you believe me. Wild stuff huh?
ID:	63076   Click image for larger version
  #18 (permalink)
Old 02-19-2012, 10:43 PM
ogre's Avatar
carved from dinosaur bone?
  #19 (permalink)
Old 02-19-2012, 11:05 PM
LOLOLOLOL, listen you young punk, the car is exactly as old as me so go chew on that!
  #20 (permalink)
Old 02-20-2012, 08:56 AM
T-bucket23's Avatar
Wiki Edits: 26
That is not unusual. Looks like a lot of fans from that era
Chet
  #21 (permalink)
Old 02-20-2012, 09:01 AM
But it doesn't seem like there are that many left! It's a dying breed.
  #22 (permalink)
Old 02-20-2012, 11:02 AM
ogre's Avatar
and i'm a year older than my truk or so they tell me when i'm lucid
you young whipper snapper
i have a set of old lawn mower blades you can try on your rumbler.
they're a little longer than your fan blades, might improve air flow
  #23 (permalink)
Old 02-20-2012, 11:05 AM
LOLOLOLOLOLOL, thanks for the morning laugh, mower blades, LOLOLOL
  #24 (permalink)
Old 02-20-2012, 06:19 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
now that is funny
  #25 (permalink)
Old 02-22-2012, 02:32 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I'd love to read the symptoms, but get an access denied message when I click your link?
  #26 (permalink)
Old 02-22-2012, 03:13 PM
ogre's Avatar
everybody did, i just like rattling martinsr's chain
  #27 (permalink)
Old 02-22-2012, 03:42 PM
I'm a little confused on the symptoms now. It seems that it simply overheats when the heater is being used. But at first it seemed to only do it when the "vent" was open. The vent is where the heater is getting air from the scoop at the rear of the hood between the wipers. It brings air into the cowl and down and over the heater core into the car. It just still seems like the darn thing will get hot when I am using the heater and the vent is open.
But I plan on doing a little static test and see what really triggers it. I just keep forgetting.
  #28 (permalink)
Old 02-22-2012, 04:20 PM
T-bucket23's Avatar
Wiki Edits: 26
Im still thinking that when the heater valve is open the coolant is not going through the radiator to get cooled for some reason. It might be interesting to put a thermometer in the radiator when the heat is running to see if the temp in the radiator goes up or down in the radiator itself. Wondering if there was some sort of restriction integrated into the heater valve that may be missing. The vent making a difference makes no sense at all.
Does it do it just sitting idling or only when moving
Chet
  #29 (permalink)
Old 02-23-2012, 11:51 PM
Semper Gumby
Wiki Edits: 2
I keep thinking (even tho my Dr says I'm not allowed to do that!) that, if the heater hoses are somehow reversed then it may interfere with the coolant flow in the engine.
If that don't fix it, then for sure the framistat is interfering with the flux capacitor, which will always affect the anti-matter converter and cause the warp cores to overheat!
  #30 (permalink)
Old 02-24-2012, 12:12 AM
It seems to overheat in traffic. This is the thing, I really need to do a static test in the driveway to see if I can make it happen. I just haven't done it, I forget if I am not driving it.
Hot Water heater troubles, got any ideas? MARTINSR Off-Topic 9 01-27-2011 09:49 PM
Ideas & Opinions : Placement of Truck Heater & AC Units horvath Interior 26 02-10-2005 03:51 PM
Interesting Vibration Problem snod83 Transmission - Rearend 13 02-01-2005 10:33 PM
routing heater hose on SBC! need ideas bigfred1958 Engine 1 02-18-2004 06:06 PM
Ideas for a eletric heater in a pro street type car? Blown72Camaro General Rodding Tech 7 10-02-2003 10:04 PM
