Interesting heater problem with my Rambler, any ideas? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 05-23-2012, 05:34 AM
Brian, you never did post what happened if you just opened the water control valve part way. That sounded like a good suggestion if, by chance, the heater was taking to much water away from the radiator.
  #47 (permalink)
Old 05-23-2012, 08:16 AM
I tried that too John, then found that I had it opened too far and the damn thing heated up because I wasn't paying attention. I have just given up and will open it for a few minutes then close it, it's like flying an airplane these old cars, you need to be on your toes. And I LOVE IT.
  #48 (permalink)
Old 05-23-2012, 05:46 PM
You are right Brian and everyone of them have their idiosyncrasies. (thank goodness for spell check). The roadster has the temp gauge in the head and the fan sensor in the bottom of the radiator. In town the fan cycles between 180 and 185. On the interstate it won't cycle on until about 205 so I just flip it on at 185 or 190. Anyone else would move the fan sensor to the other head but I am so used to it i don't think about it any more. Just flip the switch.
I really like the Rambler. It definitely has personality.
John L.
  #49 (permalink)
Old 05-23-2012, 06:35 PM
John L.
Yeah, when someone says "It fits you perfectly" I have to worry though, that's kinda scary.
  #50 (permalink)
Old 05-24-2012, 10:42 AM
Tell the truth
Hey Brian,
1. Is the guage in the car mechanical or electric?
2. Did you check engine temp. with known good guage?
3. Is vent air going through the heater or just towards it?
4. What controls the vent? (don't tell me your right hand)
5. Is there a thermostat of the correct rating in the engine?
Later, Frank and yes the cake girl is a cutie!
  #51 (permalink)
Old 05-24-2012, 11:08 AM
Originally Posted by Frankinforesthill
Hey Brian,
Thanks Frank, she is very loved that's for sure.
1. It's electric.
2. No, the thing is it reads low 99% of the time and when it goes up, it makes sense.
3. It goes thru it, into the interior.
4. Yes my right hand which pulls a vent open or closed that is over the heater core.
5. Yes.
  #52 (permalink)
Old 05-26-2012, 10:00 AM
Hey Brian,
Couple O things,
If the guage is electric and reads low 99% of the time you may have an electron problem.
If you did not conferm the real engine temp. Is it overheating?
Back to the 99%. (and not for a protest) Is the thermostat opening and closing correctly.
One more thing. You and this thread is why I joined this group. Been hiding in the shadows for a long while. The Rambler brought me out. Back in the day when I worked for a living I got all the weird and crazy things to fix.
One more, more, thing. I am really an old guy just a new guy here. Don't give a crap about "PC" but I do resepct the other guy and his opinion.
Later, Frank
  #53 (permalink)
Old 05-26-2012, 10:21 AM
You are right I need to confirm the temp.
Thanks for the ideas. Right now I am out in the driveway with it fixing the seat so I can get a wheelchair bound friend into it so I can drive him to the Goodguys show this coming weekend.
  #54 (permalink)
Old 02-25-2013, 01:42 PM
I have to tell you, I am a little red faced here. I have lived with this problem now for over a year. I would simply open the heater control valve and let the core fill, then close it and turn on the fan to warm the cabin then open the valve filling the core then closing it. If I left it open the sucker would overheat. You could literally watch the needle going up!
So yesterday I am adjusting the brakes and what not around the car checking fluids and I notice that the temp sending unit is literally two inches from the heater control valve in the head. Anyway, I just got to thinking about this problem and decided to vacuum out the system again. The rad level was about two inches down from the cap, it's a big old tank so this left plenty of coolent in there. I know I did it before and I know the heater control valve was open (I'm pretty sure I did that, it's cooling systems 101) so I vacuumed it out and left it go maybe longer, really making sure. The rad hoses were collapsed good. All the while no coolent was sucked out by the vacuuming! There normally would be a little bit being the coolent was so high in the rad. Most any time there is coolent at all in the rad you are going to get a little being sucked up. Anyway, after vacuuming it sucked in a bunch of coolent! maybe a half gallon or more. I left it there under vacuum for a lot longer than usual, it will get down to a few pounds and I often will just pull the thing off and top off the tank and that's it. But this time I left it there until the gauge read zero while I worked on other things on the car.
Today on the way to work I drove all the way with the heater on! It ran perfectly normal the whole way, it would have never done that before. There WAS an air pocket in the heater core!
Damn that vacuum system is awesome, do bad I didn't do it right a year ago.
  #55 (permalink)
Old 02-26-2013, 08:36 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I've never used a vacuum system and never had a problem with my old 61-63 Americans years ago. Heater is a bit different but in the same location and has the same hose routing. I bet you had the heater valve closed when you thought it was on. Little things like that still happen to the most experienced people! Regardless of how or why, it's nice to have it fixed I know!
  #56 (permalink)
Old 02-26-2013, 09:27 AM
I don't know but I am happy that it appears to be ok. That's what matters most.
  #57 (permalink)
Old 02-26-2013, 10:55 AM
True Temp
Brian,
As per my post of 5-24-12. Did you ever check the temp with a known good guage?
Correct me if I am wrong, all air through the core is from the vent. Hard to beleave.
You said turning the heater on or off had an effect on engine temp. Are you refering to the fan control or water valve?
Back in my day (do I sound like a TV ad?) and when that Rambler was built we didn't have a Vacuum sucker for the cooling system.
I still think you have a guage problem not a cooling problem.
Conferm true engine temp and we'll talk.
Later, Frank
  #58 (permalink)
Old 02-26-2013, 11:02 AM
LOL, I hate that common sense crap Frank! No I haven't checked with another gauge. But why is it working now?
I have another and I'll check it.
Hot Water heater troubles, got any ideas? MARTINSR Off-Topic 9 01-27-2011 08:49 PM
Ideas & Opinions : Placement of Truck Heater & AC Units horvath Interior 26 02-10-2005 02:51 PM
Interesting Vibration Problem snod83 Transmission - Rearend 13 02-01-2005 09:33 PM
routing heater hose on SBC! need ideas bigfred1958 Engine 1 02-18-2004 05:06 PM
Ideas for a eletric heater in a pro street type car? Blown72Camaro General Rodding Tech 7 10-02-2003 09:04 PM
