interesting paint combo. Care? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2006, 04:02 PM
vortmax's Avatar
I have a bike frame that I had powdercoated with a polyester based powder and then painted some detail work using Duplicolor flat black over their primer.
The paint job turned out beautifully. What I'm wondering is proper care of the flat paint. I did not clear coat over it, as the only clears I could find were high gloss, which eliminates the purpose of the flat paint to begin with. So how do I protect the finish? Will normal carbuna wax protect it without adding a lot of gloss?
Old 05-22-2006, 09:17 PM
39deluxe's Avatar
Never Finished
Anything you put on the flat black will make it more shiney. Car wash soap and air dry would be the best. Any rubbing with a towel will eventually polish it some.
I assume you used spray cans. If you can get an airbrush you can buy some clear from the automotive paint store and add flattener to it to produce the level of no gloss that you desire. Even then you will not want to use any wax or polish on it as the more you do the more glossy it will become. The clear will protect it from spotting and oil stains ect. though.
Tom
how to care for new paint on a car 63novawagon Body - Exterior 6 06-03-2008 06:43 PM
question about Souther Polyurethane paint care alden Body - Exterior 12 11-02-2005 10:33 PM
easy paint job info needed pjd Body - Exterior 1 08-09-2005 11:30 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 07:31 AM
