Interesting starting problem with the deuce - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-26-2012, 06:41 PM
Irelands child's Avatar
Originally Posted by Centerline
Adding the Ford solenoid is just an added safety device when the battery is located in the trunk. It keeps the main feed to the starter de-energized at all times except when cranking.
Centerline
HotRodsAndHemis.com
"Old age and treachery will always trump youth and exuberance." - Anonymous
That's how i originally set mine as well - but after a lot of rewire my alternator to battery charge line now goes through that stud on the starter, which made the solenoid useless and now removed. I now have a Cole Hersee 24200 latching solenoid in its place which with a momentary toggle switch isolates and disconnects the battery from the system. It's also a theft deterrent. I really don't care if there is current there as my starter is way low and almost hidden behind the headers and 'buried' with engine setback in the firewall. If I decide to isolate that part of the system, will install another latching solenoid though it will complicate the starting sequence with another toggle switch and more wiring.
Dave W
  #17 (permalink)
Old 02-27-2012, 09:43 AM
This is how my battery disconnect is wired. A second one could be used if you wanted to isolate the starter. It would have a second toggle switch, etc. Then you could do away with the suspect Ford solenoid - but it would complicate the system and still have a solenoid there, but operating differently:
Interesting heater problem with my Rambler, any ideas? MARTINSR General Rodding Tech 57 02-26-2013 11:02 AM
starting problem hman17024 Electrical 7 05-17-2011 04:27 AM
starting problem chevy c20 Electrical 6 04-24-2011 06:01 PM
starting problem chevy c20 Introduce Yourself 1 04-18-2011 08:34 PM
Interesting Vibration Problem snod83 Transmission - Rearend 13 02-01-2005 09:33 PM
