Interesting wheel damage on this Vette. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-07-2009, 09:03 PM
Last journal entry:
With such a low profile tire such as that, I'm almost positive either whatever she drove over either 1. was pointed enough to push the tire into the rim, thus ripping it -OR- 2. A large object came up and wedged itself in the wheel well and had no where to go, but into the rim.
My guess is #1. The clearance between the contact patch on the road and the rim are very close. Did your customer feel anything when this happened??
Also, what comes into mind are 'nails'. Concrete nails are huge. Maybe one got wedged just right?
  #17 (permalink)
Old 01-07-2009, 09:12 PM
He says he has no idea what it was. He felt it, but that is all he knows.
  #18 (permalink)
Old 01-08-2009, 06:29 AM
Kevin45's Avatar
Just one of the guys
By the way it looks, running over something like a rock with low profiles would do that. I've seen some badly damaged wheels from potholes and low profiles with no tire damage.
  #19 (permalink)
Old 01-08-2009, 06:49 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
My guess would be the low tire pressure sensor is what caused the damage. Either a low tire and hitting something, or at impact the sensor pushed through the rim center.
Steve
  #20 (permalink)
Old 01-08-2009, 07:37 AM
That is a thougth Steve, I was wondering if the sensor was damaged, I hadn't thought that the sensor may be the CAUSE of the damage to the rim. Hmmmmmm, we will find out soon the new wheel is due in tomorrow.
  #21 (permalink)
Old 01-08-2009, 08:11 PM
4 Jaw Chuck's Avatar
Looks like he centre punched a standard size brick which rolled up as he drove over it, another possibility is the end of a construction sign which has a 1" dia piece of round tubing welded on the end.
  #22 (permalink)
Old 01-10-2009, 09:55 AM
Kevin45's Avatar
So what was the damage caused from?
  #23 (permalink)
Old 01-10-2009, 10:36 AM
He didn't know, he ran over something but didn't see what it was.
  #24 (permalink)
Old 01-10-2009, 11:03 AM
Race The Truck
Last journal entry: Son's Truck
To me it looks like a metal rod punch it, maybe re bar sticking out of the ground.
Craig
  #25 (permalink)
Old 01-10-2009, 01:54 PM
Kevin45's Avatar
So it wasn't in the area of the pressure sensor?
My 73 Vette Story Intrigue Hotrodders' Lounge 13 01-11-2007 07:32 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
What wheel wrench fat40 General Rodding Tech 16 07-17-2006 05:34 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
rear wheel locked on 77 vette john69 Transmission - Rearend 6 10-28-2002 12:23 PM
