interior for 31 coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2002, 07:38 PM
New Member
Post interior for 31 coupe
My 31 coupe is just a bare shell.The wood is in place such as the door pilers & around the windows. Do i just use masonite or other material that you would normally use for door panels and screw it to the wood? Will it bend enough to make that corner between the qrter window and the back window?(5 window coupe)Does anyone sell these interior's as a kit?
Thanks DC
Old 11-08-2002, 08:03 PM
BOBCRMAN@aol.com's Avatar
Post
if you want to do it yourself use 1/8" untempered masonite or common hardboard it is quite versatile and with care it will conform to the corners and curves,use common door panel clips to hold them on, available for old fords, volkswagens etc. the headliner and trim parts are tacked on and edges covered in trim or hide-em welt, for a kit try Hemmings Motor News, Labaron Bonney makes kits $$$$$$$
[ November 08, 2002: Message edited by: BOBCRMAN@aol.com ]</p>
