interior door handles 64 galaxie wagon - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2005, 01:39 PM
New Member
Hey, does anyone know how to remove the door handles. I know there is a trick and probably a tool but cant push the panel back from the handle enough to see what is required. All the panels are pristine and I don't want to damage them..Any info appreciated..Thanks, Ray
Old 07-02-2005, 03:46 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
the handle has to go on after the door panel so it has to come off before the panel. some handles have a pin that goes thru the shaft, some are just a u-shaped pin or almost like a body shim that slides in the back of the handle. sometimes there's a cap that comes off the front of the handle and then there's a screw behind that.
good luck.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 07-02-2005, 04:01 PM
aka Duke of URL
If you gently pull the handle from the panel (push back)(also nylon protective washer), you will see this wire U-CLIP. It can be removed with a hooked pick but there is a special service tool available (KD TOOLS) that you slide behind the handle to release the wire hook.
Old 07-09-2005, 05:16 PM
pumpkin35's Avatar
Try this
I bought this set, and it works pretty good on a number of different cars.
http://www.harborfreight.com/cpi/cta...emnumber=38386
Power Windows 64' Galaxie slammed64Galaxie Electrical 3 02-15-2005 07:55 PM
Disk Brake Conversion 64 Galaxie bgray Suspension - Brakes - Steering 19 06-02-2004 12:38 PM
64 galaxie willie1010 Suspension - Brakes - Steering 4 03-31-2004 04:02 PM
swap in a big block 64 Galaxie RB Engine 3 06-06-2002 09:09 AM
drum to disc on 64 Galaxie RB Suspension - Brakes - Steering 1 06-06-2002 04:13 AM
