Interior door panel material
I'm getting ready to make some simple flat door panels for my newly restored microvan. I've got my old ones to use as templates. I've read a few door panel threads, and did some searching here and Google. It sounds like the black water resistant door panel board is no longer a favorite. There has been some talk of PVC panels ? ...........or other new types of door panel board ?. Where can I go to find out more information ?
Thanks Mark |
Start here for all kinds of info...
READ ME - Interior Door Panel (and more) FAQ - READ ME ...and then go here for a how-to. http://www.upholster.com/auto/doorpan.html Hopefully this helps out some!
73, You are the greatest! Exactly what I was looking for. Thanks.
Yes all good info indeed! Your door panel recipe sounds alot like what I was planning........I was suprised to call the plastic store today and find out a 1/8" PVC 4x8 sheet was 115.$ !!!
The sales guy turned me on to the Sintra @ 40 bucks and .040" ABS sheeting for 25. $ I'll go check it out. |
The place I buy from has a brand called Maxxion. It's PVC foamboard like Sintra. (This stuff is also called closed cell PVC, or expanded PVC.) 1/2 the weight and cheaper than PVC, and can be cut, glued, heated and formed too. All the rest of the info you got in this thread has been right on the money. I think you will find DAP top and trim adhesive as good as the 3M and less expensive.
Check your local sign shop for 4X8 PVC sheets, should be less than $40. The problem with any of the plastic sheeting is that you have to be very careful when installing it or especially when removing it otherwise it will break and your panel will be ruined. If the door has holes where water can get to the backside of the panel it will run down and stain the bottom of the door upholstery. Plastic door panels will not help you here. Here's my approach to door panels and I always assume the car will be driven in the rain or at least get washed where water will get down in the door. If the door has a slot at the bottom where 3 mil clear plastic can be tucked into the slot to carry the water back into the door, the I use Gaffers Tape to seal the plastic all around and any small holes. My second choice is to cover the back of the upholstered panel with the 3 mil plastic using your DAP contact cement, be careful to seal the edges. The Gaffers Tape is used in the movie industry to tape mic cables and most anything down to the floor to prevent tripping hazard on the set. It looks similar to duct tape but is waterproof, and it sticks like crazy and doesn't dry out like duct tape. I use it on every restoration but a word of caution........don't put this on the outside paint as it will most likely pull off the paint when you remove it.
Good info. I didn't think about water saturation on the back of the panel. This rig gets washed! Where can you get Gaffers tape?
Yep I googled it. I was hoping Home Depot carried it so I could go get some today, but it doesn't look like it. I'll keep trying though. Thanks for the tip. I keep thinking how sorry I would be, had you not mentioned a vapor barrier......I took off the window wiskers when I painted the doors... and haven't found a suitable replacement yet....so water will pour through down to the drains..and I just know my new door panel fabric would have been stained.......
On the older vehicles, like my truck, we employ "rain curtains." Where ever there's a place where water may enter, you secure a piece of plastic on the top-inside of any opening and feed it through to the bottom-outside of the opening, keeping any water away from the door panel and directing it down to the drain holes.
I called around today. I got Gorilla tape, black, 17 mil thick, weather proof, and sticks like crazy, it will pull paint. I'm using 6 mil clear plastic sheeting, and happily got all my door vapor barriers constructed. They came out real nice. Next up, the panels themselves
Vapor barrier pictures
Where your plastic overlaps the door openings at the bottom, any water that gets trapped there will cause rust. Try to find a way to tuck the plastic into the opening at the bottom to let the water drain back into the door. The door has drains at the bottom to let the water out. You've got the general idea though.
Yeah. I thought about that. Not sure what to do. On the front doors, there are only two fist sized openings pretty far up from the bottom, I can't figure how to make splash shields like you suggested with out compromising the vapor barrier. Still pondering.
I finished the drivers door panel tonite. A test panel. My secret material has been revealed. Hope you guys don't think I'm girly
| Recent Interior posts with photos |
| The best V-8 ever made | NXS | Engine | 167 | 10-16-2011 08:10 AM |
| Percy xx carbon exhaust gasket material - passed my first (and second) stress tests | lowROLLERchevy | Engine | 6 | 02-17-2007 09:29 PM |
| How much material for a 34 ford interior? | jaxhome | Interior | 8 | 11-13-2005 08:27 AM |
| Which material??? | SR-71 | Body - Exterior | 8 | 09-12-2005 05:49 PM |
| Material quaility?? | Bluepen | Interior | 2 | 12-02-2003 05:33 PM |
