Interior Dye - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2003, 03:02 PM
Interior Dye
I am in the process of dying interior plastic parts in my 76 Monte Carlo. Can I dye the steering wheel or will the color wear off quickley? Would I be better off using a leather wheel cover ? As always, Thanks for the help.
Joe
Old 09-26-2003, 03:44 PM
tazzman68's Avatar
Justa Freak!
IMO I think you would be better off either using the wheel cover, or just replacing the wheel alltogether....
Old 09-27-2003, 01:02 AM
ChrisMiddleron's Avatar
nothing beats new. Dye works great though.
Old 10-08-2003, 11:41 AM
If 76 Monte's had a Soft Vinyl Steering wheel you might be able to get away with using profissional grade upholstery dye. Make sure you scrub the wheel thoroughly and maybe even use some soft scrub. Those old rubber wheels are bad about oozing out plasticizers that make them gummy, not good for paint adhesion.
If it's a hard plastic wheel the interior paint isn't gonna stick that great. Imron might be a better choice for a hard plastic rimmed wheel but it will still be prone to scratches and chipping. Putting a nice steering wheel cover on the rim and just painting the horn pad might be the way to go.
