Interior glue, What is the best? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2009, 09:27 PM
smithkustoms's Avatar
Hi, From time to time I will repair some parts of my cars interiors. Ive done door panels, headliners, carpet and installed new replacement seat covers.
Only issue is I can't find a glue that will meet or exceed OEM quality glue.
3M super 77 sucks, the super 90 is a little better but still sucks.
My first jobs was in a speaker cabinet factory, And some of the cabinets they put carpet on. When they did the carpet boxes, they had a glue that came in gallon size cans and sprayed from a normal spray gun. It worked perfect. The spray gun made a nice smooth even coat of the glue and once the carpet touched the sprayed box it would not come off.
Now im not saying im looking for that same glue. That was years ago and I don't believe it would make a good automotive glue.
What im looking for is a OEM+ quality glue that is sold in quarts and gallons and can be sprayed from a spray gun.
Anyone have a clue where I could find some?
thanks
Old 12-31-2009, 09:53 PM
302 Z28's Avatar
DAP Landau Top adhesive, the spray grade, hands down the best contact cement money can buy.
Vince
Old 12-31-2009, 11:25 PM
texastomeh's Avatar
DITTO!!!
texastomeh
Old 12-31-2009, 11:34 PM
life is a temporary assignment
Dap is the only way to go...
Old 01-01-2010, 07:14 AM
cboy's Avatar
Last journal entry: Finished
Here's a place you can order it on line.
Always learning...and sharing what I've learned.
Old 01-01-2010, 11:28 AM
DanTwoLakes's Avatar
Wiki Edits: 22
3-Ms spray grade top and trim adhesive is also very good, but it is a lot more expensive than DAP.
Old 01-01-2010, 02:36 PM
Thank you guys very much. That is perfect !
It is much cheaper then I would have guessed. 3M super 90 is $14.95 per can. You can get a whole gallon of that stuff for $29.99 Im sold
Old 01-01-2010, 02:46 PM
Is this the same stuff? http://www.lowes.com/lowes/lkn?actio...273&lpage=none
I thought the name seemed familiar, I had to buy this stuff to put my counter tops in my garage.
Old 01-01-2010, 02:48 PM
Here's where I buy mine..http://www.yourautotrim.com/noname37.html Very fast on shipping,
Old 01-01-2010, 03:27 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
This wiki article may be helpful to you: Contact adhesive.
Thanks DanTwoLakes and Crosley for helping work on the article.
Old 01-01-2010, 03:40 PM
302 Z28's Avatar
No that is not the same thing, this is what you want.
Vince
Old 01-02-2010, 10:49 AM
Wiki Edits: 22
Vince is right, that stuff is for gluing counter tops. There is nothing you can buy from the big box home improvement stores that will work like HHR (high heat resistant) spray grade top and trim adhesive. You need to buy it from an upholstery supply place either on line or right at the store. Also, nothing in an aerosol spray can is even close to the holding power of spray grade adhesives that are sprayed from a spray gun.
Old 01-02-2010, 11:01 AM
texastomeh's Avatar
Or check with your local upholstery shop. They usually buy it in the 5 gallon size and will often sell you a gallon if you supply you own bucket (available at any paint store). That is how I usially buy mine for "smaller" projects. That way I know that it's fresh and I don't have a lot sitting around for a long time.
texastomeh
Old 01-02-2010, 11:57 AM
ogre's Avatar
the 'Duracell Project'
and for spraying; a used POS paint gun or those $14 harbor freight 'paint' guns work
Old 01-02-2010, 11:58 AM
texastomeh
Your lucky, I went to a few local upholstery shop looking to buy a 2 yrds of a closed cell foam to make designs in headliners. Its the same thin black foam used on vinal hard tops. All of them told me "we are not a fabric shop" Not one of them would sell me 2yrds. ended up ordering it from yourautotrim.com
I answered my own question about the counter top glue shortly after I asked.
I ordered a gallon from yourautotrim.com Thanks for all the help!
