interior handle retaining spring clip 49 chev - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2014, 08:33 PM
tapkoote's Avatar
Last journal entry: the hood finished
Being a 4 door car this thing has lots of handles and spring clips. The ones on the car are not long enough, and the ears are not turned out far enough.
Bought some doorman clips, none of which works.
Any one got a lead on bigger clips?
Thanks Pat
Old 08-24-2014, 07:57 AM
Wiki Edits: 31
Chevs of the 40's sells the right clips as well as handles if you need original type handles.. I was careful to save my originals
Old 08-24-2014, 08:13 AM
DanTwoLakes's Avatar
Wiki Edits: 22
NAPA part number BK 6653319 gets you 75 clips. They also have smaller packages. As far as the clips fitting, sometimes you have to adjust them by hand, squeezing or opening, to work correctly.
Old 08-25-2014, 10:18 PM
Not trying to be a smart ***** here, but a friend of mine had the same problem, until I showed him that he was putting the clip on the wrong side of the handle. I am not positive about your ford handle, but many cars the clip only really fits from one side.If the handle is round where it fits over the regulator, the clip can either direction. If the handle has a "c" shape appearance over the regulator, the clip goes with the open end toward the open end of the "c". If any of that makes sense. Jeremy
The Following User Says Thank You to JCAR For This Useful Post:
PapaG (08-31-2014)
Old 08-26-2014, 06:39 AM
Wiki Edits: 27
removal ?
If you put them on the wrong direction on some cars, they can be very hard to remove. Trying to hook from the handle end It took me 10 minutes last week end to get one off.
Old 08-26-2014, 07:08 AM
Wiki Edits: 22
This is a 49 Chevy he's talking about. A 49 Ford would have pins holding the handles on. These clips go on from the side away from the part you turn to open the window or door. It would be really hard to put the clip on the wrong side, and almost impossible to remove if you could do it.
ID:	169922   Click image for larger version
chevy c10 door handle interior removal ninmmkmfdm Interior 17 02-12-2013 03:55 AM
4L60e low-reverse clutch retaining clip stuck! old yukon Transmission - Rearend 5 01-25-2011 10:39 AM
Valve spring retaining rings needed? maxpower_454 Engine 1 03-18-2009 08:37 PM
TH350 rear clutch retaining spring AMDAP Transmission - Rearend 10 02-29-2004 09:00 PM
Door handle spring Lash Body - Exterior 2 01-13-2003 01:56 PM
