Interior Help Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2005, 07:49 PM
Ronnie Hogan's Avatar
New Member
Last journal entry: Project 1947 Ford
Looking for some help installing a covering on the under side of my deck lid on my 1956 chevy. What is the best material to use for the backing for the material to be glued to? Looking for someone that has some pictures of there project and how is was done, step by step.....PLEASE HELP
Old 08-29-2005, 12:06 PM
73oldsman's Avatar
I found this on the net that might help. http://forums.vwvortex.com/zerothread?id=1436376, and http://www.fatmat.com/. You may be able to use a mat sized for another car, such as one in this site (Scroll down to the H's) http://www.drclassic.com/catalog/Camaro/Underhood. The one I put in my Olds, many years ago, is held in with push in type plastic retainers that go into holes drilled in the inner hood supports. I can't remember where I got it from. My underhood is painted to match the car exterior and I didn't want to put a glue product on it, so I don't know if the glue would hold up. Later!
help needed savman1 Engine 4 06-15-2006 10:58 PM
Sealer Needed or Not? Early B's Body - Exterior 9 05-25-2005 02:21 PM
Reliable Engine Needed 76Monster Engine 30 12-26-2004 04:50 PM
what size rim, slick width and backspacing are needed? sb72elcamino350 Transmission - Rearend 3 06-22-2004 04:16 AM
1993 THUNDERBIRD HELP NEEDED ! roberto555 Engine 1 09-09-2002 08:58 PM
