interior insulation - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 06-16-2004, 10:12 AM
302 Z28's Avatar
I found some aluminumized insulation blanket at a metal building erector. It is the stuff you see on the insides of metal buildings underneath the chicken wire looking wire that holds it in place. It is about 1/2" thick double sided aluminum and is very affordable. The firms name is Metal Depot, I do not know if this is a chain or not.
Found a link to the stuff
http://www.metaldepotinc.com/insulation.htm
Vince
  #47 (permalink)
Old 06-21-2004, 05:33 AM
STUPID is as STUPID does...
There is an extensive article on interior insulation in the latest Popular Hot Rodding...
  #48 (permalink)
Old 06-22-2004, 12:02 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
We had a beautiful Summer day here yesterday, so I had some fun in the sun and finished insulating my truck-interior behind the seats. This is just "Phase One" where I've sealed up the floors and laid cotton-fiber jute.
You can see pics, etc. Here
"Phase Two" will occur after I find the powered (low back) seats I want to install -- THEN I'm gonna put foil-backed insulation (Home Depot sells it for water heaters) on top the the cotton-fiber jute. THEN I'll lay my carpet, put in the seats and start making interior panels.
Alan
54 Chevy Pickup
  #49 (permalink)
Old 07-14-2004, 07:27 PM
Hello, Im new here and I have a 240Z which is going to have a 350ci SBC and Im currently redoing the interior. I decided just to add on to this post because I have just got done por15ing my floorpans due to all the rust and are about to remove the dash and wires so I can install some insulation+Dynamat. Now 240Z have a knack for getting the interior cabins hot, real quick and was wondering what should I lay down first? The Dynamat then insulation(which I have no clue what kind to get) or insulation and put Dynamat over it. I was thinking that the Dynamat goes first but don't know how well it will hold up on the firewall and transmission tunnel as they get hot. Will this be a problem?
Thanks
Matt
  #50 (permalink)
Old 07-15-2004, 06:42 AM
Thanks
Matt
You wont have a problem with the heat and a dynamat material. You may also want to look at the b-quiet extreme. Its cheaper and as good as dynamat.
http://www.b-quiet.com/extreme.html
Jerry
  #51 (permalink)
Old 07-15-2004, 08:49 AM
horvath's Avatar
I would think the Dynamat would be all you need.
Alan
54 Chevy Pickup
  #52 (permalink)
Old 07-22-2004, 08:32 PM
Sound Deadning
I think this stuff is what you guys want.
Polymeric Mastic
0.070" 32" x 54"
-30° to +300° F
0.7 lb/sq.ft.
9709T19
$14.62
I have 3 sheets of this stuff that I have yet to put in. I have seen other installations using this stuff and it works very well and is very cheep. It looks, feels, handles, and installs just like "Dynamat" only for about 1/6 the price.
I have used roofing stuff before (I used Peel & Seal) but it didn't stick to well (other then that it works good). It did stick like mad on top of the noise killer paint even in hot SoCal summers fwiw.
I have also used some stuff called "Noise Killer" paint
http://www.noisekiller.com/Products.htm (I have about 6 coats on the back wall, roof, & floor of my s10)
It worked real well but I think this stuff form McMaster-Carr is the same stuff for less $.
This is a link to the catalog page with both the polymeric mastic and the deadning paint
http://www.mcmaster.com/pdf/110/3270.pdf
  #53 (permalink)
Old 12-15-2004, 10:01 PM
Chevydee's Avatar
What do you guys suggest for insulating and sound dampening the doors and the sides of the vehicle? I have a noisey 57 nomad.
  #54 (permalink)
Old 12-16-2004, 09:16 AM
GreaseMonkey
I use roofing materials, there are these rools of roofing mastic that have this aluminum foil face, the mastic is very thin, the mastic side has some very excellent glues to it. It comes in 3 inches up to 1 foot wide. I like the aluminum side of it because it helps in the insulation factors. I have also been known to use this on floors of trunks and the floor of car for more of noise barrier that heat barrier.
I am sure others have favorite products.
  #55 (permalink)
Old 12-16-2004, 10:42 AM
BigMac's Avatar
1949 Chevy Truck
I have bought it about a foot wide @ Lowes. Cheap and did a good job. I even put it in the door which made a big difference when you closed the door. (No more tin can sound on my 49)
  #56 (permalink)
Old 12-16-2004, 12:25 PM
horvath's Avatar
Hey, BigMac
Do you have any pictures of what you did?
Where, on the doors, did you place it? I'm getting ready to do my door panels ... do I put this on the door, UNDER the door panel??
Alan
54 Chevy Pickup
  #57 (permalink)
Old 12-16-2004, 12:43 PM
I got mine at lowes I asked for a price check on a roll aboujt 18 in by some 60feet and he said $5.00 a said I would take both rolls. I used in on the inner door panel on my 50 f1 and it made a big difference. What I did was to cut it to length and then I took a propane torch and heated it till it got soft and tacky and it stuck and held like it was from the facotry.
Originally posted by horvath
Hey, BigMac
Alan
54 Chevy Pickup
I put it behind the door panel on my 50 f1 I do plan to put in on the floor and roof before carpet and insulation. Ed ke6bnl
  #58 (permalink)
Old 12-16-2004, 03:38 PM
Chevydee's Avatar
Anyone know another option for where I can get jute? I went to Home Depot and Lowes today and I could tell by the look on their faces, that they didn't really know what I was talking about. Despite that, I looked all over for it in the store and couldn't find it. I like the idea of jute on the floor, then the lowes double foil sided insulation for the floor and the sides. The only thing I could find that you could wrap a hot water heater with is the water heater blanket. I guess jute and water heater insulation are not high-demand items here in the south. Heating up stuff with a propane torch sounds like something I would hurt myself with. Besides, my one hour of free time a day (and my pregnant wife) wouldn't allow me enough time to do it. Someone suggested to me that I also stuff jute inside the walls of the interior. Is that a good idea? I am a first-timer.
  #59 (permalink)
Old 12-16-2004, 04:18 PM
Chevydee
Don't use Jute on the floors, it holds moisture like a sponge. It will rust your floors out in no time.
If you want something like Jute, indoor /outdoor "astroturf" style carpet works great, put it down so the backing is up. That way, if it does get wet, air can circulate in the nap to dry it.
You won't need anything else.
  #60 (permalink)
Old 12-16-2004, 04:50 PM
horvath's Avatar
I got my jute at Home Depot ... in the carpet department. Look at all their rug underlayment stuff -- they only have two kinds ... one is the sponge rubber (junk) ... the other is all gray cotton with threads of different colors mixed in -- that's the jute.
It's only gonna hold moisture if moisture gets into it ... if you do things right, you shouldn't be getting it wet, eh?
Alan
54 Chevy Pickup
