interior insulation - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 04-22-2005, 03:47 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
Lead sheeting for insulation
I saw that RyanB says he used lead as a sound damper in his truck. Ryan is right that if you eat it it will kill you. But also if you touch it it leaves a residue that that you can pass onto your kids. I am a union sheet metal worker and our training says that the residue gets on your clothes, hands, etc. So after working with it leave your clothes in the garage to be washed. Kids are really susceptible to lead so You don't want to hug them till you have cleaned yourself up. Also if you grind on it...well you know the rest, it's not good either. So just a work of caution in the handling of lead. But it does work as a great sound deadener, just be careful.
  #77 (permalink)
Old 04-22-2005, 10:59 PM
willys36@aol.com's Avatar
Wiki Edits: 21
So . . . I shouldn't have chewed those lead pellets from my pellet gun all through my kid-hood?!? Shouldn't have cast the thousands of lead soldiers in my Sears Roebuck lead soldier casting set?
  #78 (permalink)
Old 04-22-2005, 11:16 PM
gator412's Avatar
mmmm Willy that explains alot...lol, by the way thanks for the help with my steering column.
  #79 (permalink)
Old 03-18-2006, 08:32 AM
Last journal entry: 1949 Chevy PU 3/4t barn find
Has anyone tried the same rubber padding used under house carpet? I would think that if using spray adheasive and it being prety form fitting that would work for sound and heat.
  #80 (permalink)
Old 03-18-2006, 10:36 AM
carpet rubber padding "is" a sponge....sucks up and traps moisture to promote rust....you want as dry as possible.....
