Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Interior-Insulation install
Old 02-08-2013, 02:42 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is online now
Wiki Edits: 22
Originally Posted by menace 65 View Post
What should a person use as a pre-cleaner on the metal door panels andinterior roof panels before installing insulation?Rubbing alcohol,MEK,or what works best?
I would use mineral spirits. That will clean the sheet metal and be less dangerous than methyl ethyl ketone. Denatured alcohol might work, not rubbing alcohol. Rubbing alcohol is only 70 to 80% alcohol, I think it has some ingredients in it that would leave a residue that you wouldn't want.
