interior light - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2010, 06:28 PM
interior light
is it safe to wire up an interior light to the door light
Old 06-28-2010, 05:23 AM
Assuming its a GM vehicle (Camaro?)
If the new light won't draw too many amps, you can tap into the stock interior lights wire. Just remember that this wire is always hot (12 volts), and the door switches ground the it and make the lights work. That is the opposite from most aftermarket accessories, which are usually grounded, and then use a switch to turn the power on and off.
Bruce
