Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Interior metal floor edge against interior body
Old 09-12-2011, 01:35 PM
55paneltrk.'s Avatar
55paneltrk. 55paneltrk. is offline
I have a Ford Panel trk. that uses 3/4 plywood for flooring. From the edge of the floor to the interior outer skin it has metal that fills that area. The metal is broke at a 90 degree that meets the inside outer body. The original product looked like some kind of felt to fill that void. This must have held alot of moisture. Rusted out from the back of doors to rear wheels and then onto the rear doors. I was wondering what i should use this day that would work the best ? Thank you all for your input, Marc
