Interior metal floor edge against interior body - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2011, 12:35 PM
55paneltrk.'s Avatar
I have a Ford Panel trk. that uses 3/4 plywood for flooring. From the edge of the floor to the interior outer skin it has metal that fills that area. The metal is broke at a 90 degree that meets the inside outer body. The original product looked like some kind of felt to fill that void. This must have held alot of moisture. Rusted out from the back of doors to rear wheels and then onto the rear doors. I was wondering what i should use this day that would work the best ? Thank you all for your input, Marc
Old 09-12-2011, 02:00 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
First you are probably up for some metal replacement but we know that..when you get the metal replaced apply a couple of wet coats of epoxy primer and then in the areas where it looks like water may get in like seams and such use a seam sealer to fill those voids..i would think that would do it for you..the felt looking stuff may be dried up old sealer that was applied when the truck was built..
Sam
how do approach interior metal rust? andy_s273 Body - Exterior 8 06-13-2009 07:20 PM
back for more (Interior floor rust cleanup/painting) alden Body - Exterior 4 02-24-2009 12:46 PM
Roll cage and interior sheet metal... fireforsin Interior 1 01-10-2006 07:45 PM
Interior metal prep. question jcarter Interior 1 11-02-2003 06:01 PM
interior metal paint? color? 59countrysedan Interior 5 09-23-2003 08:54 PM
