interior paint for steering column corvette - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2007, 09:56 PM
dmx6's Avatar
I have a 1977 Corvette that is red with red matching interior--RED not burgundy. Anyone have a current paint formula for the paint to do this column in the correct color? Dupont does not have it--their formula's are for lacquer which is no longer available. Any other manufacturer's have anything anyone knows of?
Old 10-25-2007, 10:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Southern polyurethane has 5 different shades of red...One of those usually is a good match for the Corvette red of those years..
Sam
Old 10-26-2007, 12:48 AM
Steering column paint
Hi DMX6 ,
Doesn't your DuPont jobber have a SpectraMaster book ? The SpectraMaster book has literally HUNDREDS of different shades of colors ,for solid colors as well as metallics .If your jobber doesn't have one, they should be able to BORROW one from either another dealer, or from their area rep . Once you match up your shade of red , the DuPont color computer can give the color formula in virtually ANY DuPont product . By the way, they also should be able to get their hands on a "color gun" (sorry I don't remember the right name for it) but it works by the operator "shooting" random areas of the part you're trying to match using ultraviolet light ,it then loads the info into an internal computer, which in turn comes up with the closest color possible match formula . It doesn't guarantee a perfect match in all cases , but gives a "blendable" match . We used to use both methods when I was painting cars for a living just a couple years ago . Also , as long as it is an interior part , you can use DuPont vinyl paint even on metal , as long as you use a suitable primer on the metal parts. Just an F.Y.I., Hope it helps , Rick
Old 10-26-2007, 07:17 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The "color gun" is a spectrophotometer, and they have them at some Carquest auto parts stores and also some NAPA stores have them. If you can get a good reading, they can match your paint color right on. I'm going to move this thread to Body-Exterior. You'll get a lot better answers there.
Dan
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Steering Column for 1971 Chevrolet C/10 glayman Suspension - Brakes - Steering 13 02-24-2007 01:08 PM
GM Column Wiring - Help Please Centerline Electrical 1 04-15-2005 05:29 PM
Corvette steering column loose woody51 Suspension - Brakes - Steering 4 01-28-2005 03:29 AM
