Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Interior panels?
  #28 (permalink)
Old 11-29-2006, 08:38 PM
Trim Tech's Avatar
Trim Tech Trim Tech is offline
I agree with Dan. This is the same method that we use and I will add if you have a bulky carpet at the bottom don't forget to cut back about a 1/4 inch to wrap the carpet on the bottom or if you are binding the carpet where it meets the vinyl you will have to V notch for the extra bulk.If you have trim rings at the top around the door sometimes you have to stop the panel below and just run the vinyl and foam under it.We use clear plastic very thin to make our patterns to see armrest mount holes/clip holes/window cranks and handles then transfer this to your board, it also makes it easy to make the edge of the door as you can see it. Then it you use a dry erase marker you can draw a pattern to see what it looks like!
