Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - interior prep work
Old 04-11-2006, 09:20 PM
Silverfox031's Avatar
Silverfox031 Silverfox031 is offline
StreetRods & Customs Forever
Last journal entry: 37 Ford customized WildRod "Leilani"
Before you do anything if your going to have it done by a proffessional Shop, you should consult with him, he will advise you of what needs to be done and what should not be done making it easier on both you and him. There are many issues that can save you money in the long run by doing this. Some people unknowingly create problems for the shop which, will cost them more money then job should have. Designs, materials, extras like consoles, insulation, etc. are all factors that need to be considered, and there are many more that can keep cost down or up depending on each job. So contact the shop you are comfortable with, if you know their work quality all the better, if not ask for references, examine their work, and get their input as to what you want, and costs. Good Luck
