Interior Rust Prevention/Noise suppression - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2011, 02:47 AM
I am building a 1967 Imperial Crown lovingly known as The Wanderer. I will be pulling up the carpets tomorrow and removing the sound deadening material. This is a slow rebuild due to the economy and all but I am doing each step to the utmost best I can. I have found minor rusting on the passenger comparment floorboards. I plan to use a wire brush on a drill to remove all rust and paint and so on. Then clean with a vaccum and acetone.
TO THE POINT...
I am considering a spray on liner such as Rhino or Line-x and am wondering if anybody else has done this or advice on other products.
Thanks,
Dan
Old 05-05-2011, 07:54 AM
Young Gun
I'm currently doing the same thing in my Rivi.
clean it up, patch holes, seam sealer....blah blah blah.
after all that, I'm using rustoleum's aresol bed liner and some stuff called Peel & Seal. It's a roof flashing material with the same specs as DynaMat......but way cheaper.
Old 05-05-2011, 08:38 AM
DanTwoLakes's Avatar
Wiki Edits: 22
There is a reason why the Peel & Seal is a fraction of the price of Dynamat. They may look a lot alike, but Peel & Seal does not have the same specs as Dynamat. Peel & Seal is an asphalt based product and Dynamat is butyl based, and it has higher temperature ratings than Peel & Seal. Dynamat is overpriced in my opinion, but there are other products out there like Fat Mat, B-Quiet, RaMat etc. that are better choices than Peel & Seal.
Old 05-05-2011, 03:56 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Thanks,
Dan
Dan,
I sprayed the underside of my Body with SPI Bedliner-it's great stuff and will stick/last much longer/better than anything you can sprya on in a spray can-
http://www.southernpolyurethanes.com...ct%20lines.htm
Old 05-05-2011, 06:54 PM
Wiki Edits: 22
I would use SPI bedliner or any other bedliner spray or brush on material before I would use Dynamat. The reason is that there is only so much benefit you can gain from any of these products, so why spend twice or three times as much to get the same result?
Rust prevention inside the chassis rails Eric S Body - Exterior 3 04-09-2008 11:43 PM
rust prevention for parts submersed in gasoline gms4233 General Rodding Tech 4 10-05-2005 11:24 AM
rust prevention (cooking) daimon1054 Body - Exterior 7 01-27-2005 08:44 PM
Frame rust prevention 302 Z28 Suspension - Brakes - Steering 6 03-19-2004 06:33 AM
Rust prevention question 92redgt Body - Exterior 3 03-14-2004 05:33 PM
