interiors - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2002, 08:57 PM
Post interiors
I am looking for some info on getting my fiberglass t body ready for upholster? Some people say fiberglass wood inside,some people say put a metal frame inside. Info with pictures would be nice. Would somebody please tell me what all those little icons are for, as this is my first time. Anyway thanks.
Old 02-24-2002, 10:17 AM
Post
well, In all reality you should have both in there, steel for the strength and wood for the interior to be tacked to. I put wood around all openings and corners in my coupes so the interior guys have something to go off of, but I also back everything up with a solid steel frame to keep everything where it should be; ie door alingment and so fourth. wood moves about the same as fiberglass where steel does not. Use a hardwood,, as mounting stuff to it will be stronger. do not adhere anything to a exterior panel on a fiberglass body ar have anything touching it as it will "track"through leaving a bump on the oposing panel. So when glueing in your wood try to keep it around door and window jams. I have pics of our inner structures on my web site if you are curious to see some. bestbuyrods.com on the 33-34 page you will see structures
Old 02-26-2002, 02:43 PM
Lightbulb
A good friend and me are building a t bucket each and have some experience on the interior but not a lot. I've used square tubing but it's hard to bend around the rear corners where you you have to bend the corner and it drops at the same time.We made a bender by welding a piece of quarter inch square key stock around the center of a piece 3" pipe about the width of the square tubing. welded the pipe to a piece of channel iron and put a round cap on(just a circle cut out of 1/4 plate) to keep the tubing from buldging out. They make gate frames like this. you'll need a stop at the beginning point to hold the tubing while bending. I used a small piece of 1/4 thick flat bar. the key stock collapses the inside of the bend but stays real strong. Now that works good until you have to put a drop in it like at the corners, and I haven't worked that out yet. But the uses of the square tubing are endless in fiberglass cars or metal cars. I did have a lot of luck using this meathod at the cowl where I could anchor the windshield brackets and support the steering column. Anyhow I hope this helps.
