Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intermediate (1-2) Accumulator Spring - in or out? shift quality?
Old 06-08-2006, 09:05 PM
Warrant's Avatar
Warrant Warrant is offline
72 Nova, 65 Rambler, 37 Chevy
I'm on the final steps of finishing the rebuild on my th350. Reading through my rebuild book, it says many Hot Rodders leave out the 1-2 accumulator return spring, which will cause more abrupt shifts? Is this something I would want or should do...I put in a transgo shift kit that just fixes the softer shifts(not the hard shifting performance kit)
BTW when I pulled the trans apart the spring's top was busted off-about 2 coils...So I went to local trans shop to replace it, he only had a purpleish one, and the original was redish. I think one is for a six cylinder engine and the other is for a 8?? Will that be ok?
Spring in or out? How will that effect the 1-2 shift? Also, if purple spring is for a 6 - is that a stiffer or softer spring?(Book says stronger spring causes softer shift)
Thanks a ton
