Intermediate (1-2) Accumulator Spring - in or out? shift quality? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2006, 09:05 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I'm on the final steps of finishing the rebuild on my th350. Reading through my rebuild book, it says many Hot Rodders leave out the 1-2 accumulator return spring, which will cause more abrupt shifts? Is this something I would want or should do...I put in a transgo shift kit that just fixes the softer shifts(not the hard shifting performance kit)
BTW when I pulled the trans apart the spring's top was busted off-about 2 coils...So I went to local trans shop to replace it, he only had a purpleish one, and the original was redish. I think one is for a six cylinder engine and the other is for a 8?? Will that be ok?
Spring in or out? How will that effect the 1-2 shift? Also, if purple spring is for a 6 - is that a stiffer or softer spring?(Book says stronger spring causes softer shift)
Thanks a ton
Old 06-08-2006, 09:35 PM
Jmark's Avatar
I tried mine both ways and noticed NO difference in shift feel. Used a good shift kit and it was fine, left the sping in.
Old 06-08-2006, 11:45 PM
My friend's '75 truck (350, 2bbl, pegleg) has no spring in the 1-2 accumulator. It blew out and we couldn't get it back in. At light throttle, the shift is firm, but not obnoxious. At medium throttle and above, it's kinda harsh and will chirp the tire no problem. I'd use one if possible.
Old 06-09-2006, 11:37 AM
Warrant's Avatar
Whoops, I wasnt payin attention....Thought I was in transmission furom, can somone please move it. Thanks
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 09:20 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 10:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
