Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - intermitent high idle
Old 08-11-2009, 03:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 85_Olds
i think ill spend the weekend playing with it to see if i can see anything visualy sticking or binding.
Good idea. You mentioned modifying the choke- You might start there when looking for anything causing the throttle blades to stick open some, the fast idle cam/linkage could be the culprit here.
I would have seen where the curb idle stop on the linkage was at, when the engine was in "fast idle mode", if the stop was OFF of the curb idle screw, you would know for certain there was something holding the throttle open some small amount.
