intermittent knock, whats your guess - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2003, 03:56 AM
mikeweyman's Avatar
Last journal entry: 2 years later
hi folks, another question for those smarter than I.i have a 90 bronco 2 ,2.9 litre , so here's the problem.upon start up the truck runs fine , sometimes it taps like a bugger,sometimes not.i can be driving along fine ,then it will tap like theres no oil in it (sounds like 1 valve ?)it goes from running like a million, to a half milion mile motor sound.in seconds flat.
i am thinking it is a bad rocker arm(bent?)as it is intermittent and the motor is kinda putting and losing power while under accelleration ..but only when its noisey.it could be a valve??or maybe the oil pump is weak???
any opinions will be greatly appreciated.mike . the more ideas the more things i can check...
Old 09-16-2003, 04:08 AM
Frisco's Avatar
Glad To Be Here
Check for a bad EGR valve or the connection at the EGR.
Old 09-16-2003, 05:39 AM
BOBCRMAN@aol.com's Avatar
sounds like a hydraulic lifter with a sticky internal relief valve.
Old 09-16-2003, 06:47 AM
roys63's Avatar
Check the oil pressure may have a sluged up pick up screen, you my be able to flush the oil pann with carb cleaner.
Old 09-16-2003, 08:09 AM
mikeweyman's Avatar
thanks guys , i really appreciate the help. i guess i'll have to take off the valve covers if its not the egr. and check for any signs of wear or damage.
