Intermittent Problem - 4L60E - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2006, 01:32 PM
edge's Avatar
Time is short, are you ready?
I have a 94' Suburban with a 4L60E.
It was rebuilt about 22,000 miles ago and ran flawlessly for about the first 18,000. Then it started to have an intermittent problem. This is maybe once every 2-to-4 weeks between episodes. I have not changed the fluid and filter yet and am planning to do that soon. But before I drop the pan, I figure I will run this by the experts to see if anything else should be done at the same time.
Symptoms:
  • It happens after the vehicle has been driven once in the day. So it is a restart condition
  • It idles high when first put in, like converter is not engaging
  • It will upshifts very hard
  • It will not downshift when accelerating
  • It feels like it is slipping when in high gear or overdrive
  • I am pretty sure the lockup converter is not locking when driving
  • It will do it in cold or hot temps, damp or dry outside
About 99% of the time it drives and shifts perfectly. But every so often, it has the above described problem. I can let it set for 30 minutes or more and the problem is gone. The majority of the time the Suburban is not driven far, but it concerns me if we where on a road trip or having to get on the interstate.
Any thoughts are appreciated. Thanks, Ed
Old 03-11-2006, 03:04 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Total Mileage on the vehicle?
have seen the engine check light on?
Does the engine check light come on when the igntion key is first turuned to the 'run' position?
is the tranny full of fluid?
Has the computer been scanned for codes or code history?
many items you describe should set a trouble code of some type.
Is the speed_o functioning correctly?
Does the engine run good?
Could be many things that is feeding incorrect info to the PCM or an internal problem.
Old 03-11-2006, 08:11 PM
edge's Avatar
268,500 miles
It stays on since the TBI system is no longer installed. I run the engine using a TPI from my 91' GTA using a 7727 ECM. The TPI harness has jumpers for TPS, MAP and distributor.
Yes and it looks good
Just scanned it and came up with a few associated with the fact that the TBI is disconnected. But I did see coolant temp sensor is low and TPS is low. I noticed that the TPS is only .49-.50 volts at idle and should be .54 on Speed-Density. But is was shifting fine when the TPS was reading low.
Yes, but on very rare occasions it will jump around. But this never coincided with the transmission shifting problem.
Yes. It is a stock replacement crate engine with only 32k miles on it, running a TPI system.
I hope it is nothing internal. I may replace the TPS and change the fluid/filter and see what happens. Thanks for the suggestions, Ed
Perhaps I will replace the TPS
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Intermittent headlight problem Rhansen Electrical 8 01-31-2005 07:16 AM
Piston/valve interference problem jameskirk1 Engine 12 12-03-2004 04:14 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Temperature Sending Unit problem Centerline Engine 3 11-12-2004 05:13 PM
