Internal problem or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2005, 07:28 PM
Not really a hotrod but still a trans probem nonetheless.
Car is a 94 geo storm, problem is that the shifter refuses to move.
I unhooked the cable from the trans linkage and the cable moved easily so its not that.
Then i took a big socket and tried to move the linkage manually and it moved but with a lot of resistance.
I was able to move the linkage all the way side to side and it drove in all the gears.
What could possibly be the problem?
Old 10-06-2005, 03:48 PM
New Member
Stuck shifter...
I'd consider checking whaever is used to LOCK the shifter when the key is out. I've seen this happen to shifters and steering wheels (which sometimes need to be "jiggled" to get your key out).
Tom
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
*&%##*^#!! starter problem solved!!!! 85 vette Engine 12 02-22-2005 08:12 AM
Newest Transmission problem RObs71Nova Transmission - Rearend 4 01-30-2005 07:00 AM
Piston/valve interference problem jameskirk1 Engine 12 12-03-2004 04:14 PM
Internal vs External Balance 614streets Engine 3 05-28-2003 01:25 PM
